Click to Support Signs101 ...
I would say........ Plasti-dip (with a better name) and some UV protectant on top. Ask the customer for the video of a removal. That would be interesting to see.
I don't see the point. The time it took to mask... Apply the special liquid letting it sit for xx minutes... Then spraying... I could be done wrapping two roofs.
Only.benefit I could see is if you have a tricky antenna that requires Removing half the vehicle interior to get to.
I use this stuff for emblems and rims, sometimes oddball small stuff I don't want to wrap. It holds up decently well and lays on smoothly, even for a novice sprayer like me.
It only comes off well if you add enough coats, otherwise don't bother.
That may not be plasti-dip... that could be autoflex. AutoFlex is a rubberized semi-hardened paint that can be sliced and peeled away when you want to remove it.
Here is a guy I've followed online for a few years. He started out using the Plastidip product on auto rims and has grown it into his own line of "dip" products.
