Loading Omega issue...
Discussion in 'Gerber' started by Arlo Kalon 2.0, Aug 14, 2005.
  1. Arlo Kalon 2.0
    Arlo Kalon 2.0 Very Active Member
    2,467
    52
    48
    Oct 21, 2004
    Reno, TX
    A tech support guy @ Gerber on Friday asked me to load my new Omega 2.1 program into a second computer I told him I had (this was after we spent nearly 3 hours ascertaining that there were unexplainable problems with the 1st machine). It won't load into the second machine at all - at least, not the actual Omega program.
    I easily got the Rainbow Sentinel driver set up, verified the USB port for the security key, and loaded all the "extras" on the CD. But ALL it will do is stare back at me when I try to select INSTALL OMEGA. The machine where this is happening is an AMD Athlon XP 1.6Ghz w/ 512 mags RAM.
    I was able to install Omega on the first machine... but the Edge still gets DATA ERROR messages every time. We have RULED OUT a hardware issue with the Edge itself, but not with the parallel port (correctly set to AT). So, we thought "go with the other machine". I was wondering if maybe the fact that I was upgrading from GA 6 and had to do the "program" the security key deal on the FIRST machine, and then take that key to another machine would be gummin up the works somehow?
    There is no reason apparent why this should not be working right now.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    If Omega will launch on the first machine then it is seeing the USB key and it has been converted to your upgrade version successfully. Installing onto a second machine, providing you are using the same CD as the first should give you a ready to use install.
  3. Arlo Kalon 2.0
    2,467
    52
    48
    Oct 21, 2004
    Reno, TX
    Last night, I re-installed a scanner I'd had on my computer the Edge has always been connected to. This morning, while getting ready to call Tech Support bright & early, I fired it all up to make notes of what the error messages were. Everything is fine again, and the new PCI parallel port I added for the Edge is working right,... ALL since putting the OLD scanner back on (I put a different one on at the same time as everything cratered for a solid week). Looks like all along this would've been the fix - NEVER needed the Omega upgrade from GA to fix it... man - DO NOT tell my wife! HOW DID I EVER live w/out Omega???
