WOODBS
i have been doing alot of install only lately for some local sign shops. Mostly wraps..well, i was hired recently to "patch" a mess up on a sprinter. basically the indentation was tented and stretched in as far as possible, then sliced and pushed in with lam tape after. obviously it was pulling up, they reprinted the indent only with bleed, being that the panels were stretched and applied in panels, they printed the patch as one horizontal piece...no worries. with no special instructions, i removed the indent and replaced new one, really no way to overlap to hide the white "ceiling, floor, and sides" and align correctly with text etc, so i made a clean straight cut on the existing print leaving the white show. again trimmed the new panel on the tight bend, so a 5/8" white showed...looked great from side view and will not fail. sign shop says customer wanted to cover all white area, unacceptable! i think i should have been instructed of this prior to install, which i would have explained the alignment issue.
Being that the wrap was applied incorrectly to begin with, i feel i did the correct thing here. Now this wrap has other issues than this like bubbles, vinyl hanging on corners, etc..
like the song.."am i right..or am i wrong?"
