looking 4 a good transfer tape for Gandi's UV SUN inks.....
KR3signguy
currently our transfer tape does't adhere well to the UV ink & masking tape doesn't want to either untill you burnish it in, resulting in the inkchipping afterwards.
Any suggestions?
KR3signguy
to transfer a custon routed graphic.
On rare occations we'll print a contour cut graphic which needs to have transfer tape for either our installer or the customer.I could easily switch to a solvent print but I'm looking for a tape that can work with the UV
WDP
Sounds like you need a very low tack tape or your inks not bounding? Simple transfer tape shouldn't do that. Maybe there's an ink problem. Just a suggestion.
KR3signguy
the ink's great, knock on wood but it's properties reject adhesion & I have no idea why.
low tack or standard is too light.
Masking tape has the right adhesion but pulls the ink off in spots.
schurms
It comes off cause it does not stick correctly......................you have ink adhesion problems....................
KR3signguy
actually the ink adhere's quite well.
The ink only pulls up in tiny spots if I burnish masking take really hard into it.
I'll look into the 600 3M.
