Looking for…
drewpiercer
So I’ve never posted in a forum before so hopefully I’m posting in the right spot and such, I did search first and couldn’t find anything that way either so here goes.
I’m looking for something rigid probably around half the thickness of a credit card, for direct print with an eco solvent printer, preferably 30” but I can always cut it down
I’ve been hunting google forever and can’t seem to find what I’m looking for, not that I even know exactly what that is. Help.
Andy
Yes,
I print on an old roland fj52 as well as a sc545-ex
The 545 has media clamps, which help control,the sheet
What we normally do is CAREFULLY put some tape, like a thin duct tape on the underside, limed up with the grit rollers. Then theynhave something to bite into. It's easier if you line up a small table or conveyor for in & out guides for stability. Keep head in highest position. Setup as sheet
Be very careful about head crashes!
I hesitated to respond and encourage you, but it is possible, we do it
2B
fully rigid?
don't know of anything that thin and still "rigid"
have you looked at Polystyrene?
James Burke
Andy
Finished dimensions?
JB
drewpiercer
fully rigid?
I guess I say rigid because all the semi rigid stuff I see is only around 6mil and and adhesive backed. I definitely want it thicker than that. I think of a credit card in it small form is pretty rigid but if you had a larger sheet of the same material it would probably be pretty floppy lol
Using materials not really meant to go through an eco solvent machine means you must be sure you can find an appropriate profile and the material needs to be able to be pre-heated enough to accept ink and then heated up for post printing. These kinds materials seldom exist. If you get it to work, odds are you're not going to have a very good bond. As mentioned, this is what flatbed printing is for. OR........ print on vinyl and adhere to a .010 piece of styrene.
MNT_Printhead
Working among the Corporate Lizard People
You might look into Sihl 3241 Display Pro, it will flex but it is 11mil polyester film. I use it for double sided posters on the HPs I run.
10sacer
Andy
high density polyethylene (HDPE)
