Looking for a Hot Laminator
Ditchmiester
Need to laminate a film that requires about 250 Degrees F for temp on both a top and bottom rolls. Looking for input on where to start looking: Brands, New vs. Used, Etc.
Thanks.
jmcnicoll
Big AGL fan, built to last. Biggest question is how thick of lams? If using just 3 mil lams you can get away with lower end units, but if you plan on using 5 or 10 mil films buy a big boy!!!!! We have a $12,000 GBC unit that could not handle the thicker films for any distance, heat gets sucked right out of the rollers. With the big laminators you can lam the entire roll while staying up to temp.
TCaruso
Agl 4400
Hello all,
I'm new to this forum so I apologize if I'm late to the discussion. AGL builds a 44" laminator called the 4400. It may be smaller but it has all the features of the much larger 6400. Dual metal rod heaters for a consistent temperature profile, not quartz light bulbs, pneumatic controls, non crowned rollers, etc... visit www.aglinc.com for more info.
