Looking for any script writers
myront
Dammit, make it faster!!
I have a free script that I found and would like to modify the code. I messed around a bit but can't seem to get what I'm after. I'm more familiar with vbs.
Any "scripters" here.
my unix (sco 5 & redhat 7 +8) programmer tried an experiment the other day and asked copilot to
write him a couple scripts. SURPRISINGLY, he found that he only had to "touch up" the finished
product a bit to make it usable
WildWestDesigns
That's because of MS and their being behind TS as well as Co-Pilot I would imagine. But that's me speculating.
myront
Ok, been working with Copilot for a few hours. Works great but cannot, for the life of me, get the height of my created rectangle to size height properly. Seems no matter what mod I or Copilot does to the calculation, either it ends with doing the opposite or stays the same.
WildWestDesigns
Without seeing src it's hard to say one way or the other. Someone that uses scripting and the program may be able to help out at that point.
myront
What generally, or specifically, are you trying to do? Is this in Illustrator?
Yes, illustrator.
Think I got it worked out. Bounding box of text is different than if the text is outlined. So script to outline text first then do the rest.
WeedLines.jsx
// Check if there are any selected objects
if (app.selection.length > 0) {
// Group the selection first
app.executeMenuCommand("group");
app.executeMenuCommand("outline");
var selectedItems = app.selection;
var minX = Infinity, minY = Infinity, maxX = -Infinity, maxY = -Infinity;
// Calculate the combined bounding box of the grouped shapes as a whole
for (var i = 0; i < selectedItems.length; i++) {
var item = selectedItems;
var bounds = item.visibleBounds;
minX = Math.min(minX, bounds[0]);
minY = Math.min(minY, bounds[1]);
maxX = Math.max(maxX, bounds[2]);
maxY = Math.max(maxY, bounds[3]);
// Increase the bounding box width by 0.1 inch and height by 0.1 inch (converted to points, where 1 inch = 72 points)
var widthIncrement = 0.1 * 72;
var heightIncrement = .1 - 72 / 2; // Correct height increment
minX -= widthIncrement / 2;
maxX += widthIncrement / 2;
minY -= heightIncrement /2; // Decrease minY to extend downward
maxY += heightIncrement /2; // Increase maxY to extend upward
// Create a new layer for the rectangle and lines
var layer = app.activeDocument.layers.add();
layer.name = "Rectangle and Lines";
// Create the rectangle with increased dimensions
var rectangle = layer.pathItems.rectangle(maxY, minX, maxX - minX, maxY - minY);
rectangle.filled = false; // No fill
rectangle.stroked = true;
rectangle.strokeColor = app.activeDocument.swatches.getByName("Black").color;
// Create the vertical line segment
var verticalLine = layer.pathItems.add();
verticalLine.setEntirePath([[minX + (maxX - minX) / 2, maxY], [minX + (maxX - minX) / 2, minY]]);
verticalLine.stroked = true;
verticalLine.strokeColor = app.activeDocument.swatches.getByName("Black").color;
// Create the horizontal line segment
var horizontalLine = layer.pathItems.add();
horizontalLine.setEntirePath([[minX, minY + (maxY - minY) / 2], [maxX, minY + (maxY - minY) / 2]]);
horizontalLine.stroked = true;
horizontalLine.strokeColor = app.activeDocument.swatches.getByName("Black").color;
// Ungroup the selection at the end
app.executeMenuCommand("ungroup");
// Deselect everything
app.selection = null;
ikarasu
Use chatgtp. Feed it the code, tell it what it's doing wrong and it'll likely fix it ... I find it works better than co pilot.
AI is great for code... IF you can read the code.
ikarasu
Yes, illustrator.
WeedLines.jsx
Are you just selecting a text, outlining it and creating a bounding box .1" past to make weeding easier?
Is it adding additional vertical / horizontal lines based on a specific criteria?
WildWestDesigns
While AI has it's issue that make it not quite the shiny best thing out there, it depends on the language as well. JS/TS are the most written about (and I do believe JS, maybe not TS, is the most popular language out there, it swaps with Python some years(I don't actually like either, but to each their own) languages so there are tons of sites to scrape for the info (might be a little harder since this is scripting within a specific program(s) (may have to mention that this is for the Adobe "runtime" and not necessarily for Node, Deno, Bun, SpiderMonkey or V8 etc (while there is a lot listed there, not much difference between them outside of who controls what))), that contributes to how "great" it is.
myront
Yes, this is to make weeding easier.
We have FineCut plugin but only on 1 pc and that's used by our print/plot tech. So instead of tying up his pc to do this task I decided to write my own that the designers can do from there own workstation. I have a l lot more set up that way too.
I made a macro to do this in CorelDRAW. It was super easy (see below). The script from above doesn't work so well in illustrator. The rectangle size doesn't end up up correctly in height.
JBurton
Signtologist
So, I'm all for free, and diy, and scripting, and ai, but what's with the focus on Illustrator? I thought you were a corel kid?
myront
Yeah, I much prefer Corel but when I point out that corel can do something by way of a macro that illy cannot I would like to be able to present the same in script format. Plus I like to dabble with scripting.
copilot seems to have been spawned by the same people who gave us BING with a little bit of EDGE thrown in.
anyone who remembers WINDOWS MILLENIUM will be able to follow my thought process on this
JBurton
Signtologist
I see. I thought you'd been forced into illy for some reason and had been trying to get the same functionality out of it.
Have you tried feeding chatgpt your corel script, then telling it you want an equivalent script for illustrator? (When I was a kid, I got really good at working out the best phrasing for google to produce answers within the first page. I knew I wasn't smart, but I could talk to the google gods easily, so I came across as the computer guy. I'm worried we are only going to be teaching kids like mine how to ask chatgpt the right questions for the right answers...)
WildWestDesigns
And be ready for it in every orifice of your latest OS experience as well.
ME(aka Mistake Edition). Although I will maintain Win98(not SE) was the pinnacle that they had ever done for the DE experience. But that is just me.
WildWestDesigns
That's the "G" version. I don't like "AI" at all (basically just a web scraper right now) and it's level of abstraction is really going to just make people lazy and not critically think. Even with the 1st generation of users, that have best chance of knowing what is being abstracted away and to be able to handle if something goes wrong or it goes offline (which has happened quite a bit) is having a hard time dealing with those downturns. I don't have much hope. Particularly when those are just going to be taught the abstraction and not what is underneath the abstraction. Don't have to go without or avoid it, but knowing what's going on under the hood will time to time come in handy, but I digress.
