Julia at Paragon
Hello, We have a Graphtec FC7000 that is suddenly acting strangely. The head that holds the cutting blade is moving up and down on its own accord.
I called Graphtec Tech Support and they said this machine is not longer supported. The tech suggested that from the sounds of it my solenoid in the cutter assembly may be bad. And of course suggested purchasing a new Graphtec cutter.
We are currently looking for a replacement solenoid, or some advise on if you've had this issue happen, and what did you do to fix it?
thanks in advance!
Julia at Paragon
thanks in advance!
Julia at Paragon
