Looking For Water Jet Or Cnc Cutter In Dfw
bannertime
I've had two request for reverse cut signs. I'm doing other signage for these jobs so they asked if I could do these. I told them I would and if I couldn't I could get them in touch with someone that can. So I'm looking for someone in the DFW area that does CNC work. I've asked around a few places near me, but they only seem interested in large specialized contract jobs.
One job is about 2ft x 8ft and the other is about 3ft x 6ft. Would prefer .063 alum. One of the signs is going to be double sided sandwiching a sheet of .063 or maybe .080, then bolted into an angle iron frame. The other is going to replace ground level sign faces on a double sided backlit monument sign. Each sign is simple text.
I don't really want to use a router and I have considered plasma cutting them. Any help appreciated.
rossmosh
I wouldn't rule out a CNC. That should be pretty manageable for just about any decent CNC router. Find someone that has a 5x10 machine and you can do it out of one sheet if you're willing to change the dimensions of your signs a bit.
