Looking to buy a new roll fed uv printer
Discussion in 'Miscellaneous Printers' started by uv, Nov 7, 2018.
  1. uv
    uv New Member
    21
    Feb 12, 2014
    Australia
    Hi Everyone, I hope your machines are buzzing away!
    We currently have a fujifilm LED UV printer that we use to print mostly window PET films, and it has lost 2 heads and the suppliuer wants $4200 per head.
    Looking for a good replacement printer
    We have seen the mimaki UVLED but the white ink fails if it gets too wet and is unaceptable for us.
    Does anybody have any experiance with anything similar and also any recomendations for a upgrade printer?
    I no there is the Roland UV and Mutoh UV
    Also does anybody know where to buy spectra diamatix heads from? digi print took my money but now have said the supplier does not have and do not know when they will be available?
    any info would be great
  2. BigfishDM
    BigfishDM Merchant Member
    5,044
    423
    83
    Jun 22, 2009
    All Over
    What is the application that is getting too wet for the Mimaki, I have not experienced that problem with their white ink.
  3. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,302
    808
    113
    Aug 2, 2011
    Denver, CO
    This happened to one guy on a very specific material and is not true for all other users. I have customers all over the country who use the white ink without fail. Don't rule it out because it's a great machine!
  4. BigfishDM
    5,044
    423
    83
    Jun 22, 2009
    All Over
    FYI the LUS200 inks are now available for these units for the car wrap guys.
  5. aparat
    aparat Member
    38
    4
    8
    Nov 8, 2015
    Slovenia
    I have some heads if you need
  6. CL Visual
    CL Visual Member
    169
    38
    28
    Jun 8, 2016
    Copiague, NY
    I've done a lot of research on roll to roll UV printers. I ultimately went with the Mutoh 1638UR and have been happy overall with it. I do wish I waited as Mimaki has now introduced a clear varnish for their unit. The Mimaki is probably the way to go at this point since it has the integrated cutter. It also has the ability to easily print 3 layer and 5 layer decals with contour cut which the mutoh doesn't have the ability to do.
    Keep in mind that both of these machines are slow. 4x8 print with white ink takes at least 45 minutes, maybe longer. 3 layer printing consisting of cmyk - WW - cmyk, a 4x8 could take 2 hours. If you are producing in mass, neither of these machines will fit the bill and you'll need to go to something faster. Most of what we do are one off prints for events that mount on mirrors and we dont mind having the print take all day.
    I went with the mutoh for the distinction of the clear cartridge. It looks amazing to spot varnish on a matte film like a wall wrap. If I had to do it over again, I'd go with the mimaki now since it has the clear and the inline cutter. The bag system on the mutoh sucks as well. Always have to shake them, says they're empty when there is obviously 20% left in them. Have to change ink cards all the time. Mimaki has bottles and looks like a much more simple system.
    Also, the white ink running on wet apply was quickly fixed when mimaki switched to an ink that 3m manufactures. I think thats the LUS170 but don't quote me on that.
    Good luck with your purchase!
  7. uv
    uv New Member
    21
    Feb 12, 2014
    Australia
    The mimaki reps printed some white ink on optic clear PET film and soaked it in water for a while and the ink just wiped off.
    I was worried when installers wet apply it would be a problem.
  8. uv
    uv New Member
    21
    Feb 12, 2014
    Australia
    I'm in Australia.
    Do you know if its out here yet?
  9. uv
    uv New Member
    21
    Feb 12, 2014
    Australia
  10. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,419
    309
    83
    Apr 11, 2012
    Australia
  11. BigfishDM
    5,044
    423
    83
    Jun 22, 2009
    All Over
    It should be for sure.
