Lxi, graphtec ARMS question.??
Discussion in 'Graphtec' started by EZAMORA, Jan 29, 2007.
  1. EZAMORA
    EZAMORA Member
    30
    May 8, 2006
    Bakersfield ca
    Hi every one!! I was just wondering.. i have a Graphtec fc7000-75 and well i was trying to figure out that ARMS thing.. signwarehouse sold me the plotter with that VE lxi master +.. I been trying to print and cut out but i dont know where to start?? Im thinking that VE lxi master + dont work witht that ARMS. It would really tick me off if it wont work.I know that Roland comes with the software to do that and well graphtec dont... am I right.. If VE Lxi master + does work please let me know... it will be a lot of help
  2. mladams7259
    mladams7259 Very Active Member
    1,319
    Need more info to help you.......
    What are you printing with?
    Are you printing registration marks when you print?
    Do you know what "THAT ARMS" thing is for?
    What have you tried thus far?
    What are those results?
  3. TexasBob
    TexasBob New Member
    4
    LXi is basically the lower end version of Flexi, designed spefically for cutters. So no, you will not be able to contour cut using LXi. There is, however, a work around if you have the right software. Graphtec has plugins for CorelDraw and Adobe Illustrator. You can contour cut using either plugin, I believe. Check the graphtec site for the manuals on how to install the plugins and how to do the contour cutting - it should have manuals for both of them there I think.
  4. EZAMORA
    EZAMORA Member
    30
    May 8, 2006
    Bakersfield ca
    thanks you Texas...
  5. JBarraxSW
    JBarraxSW Member
    229
    2
    18
    Jan 31, 2007
    Texas
    Texas Bob is correct. LXI is not designed to support digital print applications. The simplest way to do this is to use FlexiPro which drives Graphtec's automatic ARMS system.
    The sales consultant from whom you purchased your plotterr packages should have recommended this if he or she knew you planned to use the plotter to do contour cutting. I appologize for any inconvenience this has caused you.
    Please give us a call so we can get you the software you need to do this efficiently.
    Jerry Barrax
    Equipment Sales Director
    SIGNWarehouse.com
  6. EZAMORA
    EZAMORA Member
    30
    May 8, 2006
    Bakersfield ca
    sorry about that....
