lxi on new computer problem
Discussion in 'Flexi' started by Greenthorn, Jan 10, 2007.
  1. Greenthorn
    Greenthorn Member
    147
    I have put together a new computer and am having an odd issue with LXI Master Plus connecting with my plotter (Lynx-24).
    It will cut fine, but it won't "poll" the plotter for the cuttable material width. The Lynx plotter is a low end plotter and doesn't have any type of display or screen on it, so I have to rely on the software to "poll" the plotter to check the cuttable material width.
    I have confirmed that the com port settings and the plotter settings within LXI are identical to my old computer. Yes the settings are identical except that the actual com port used is different.
    I find it odd that I can send cut jobs and they come out fine, but the "poll" option in LXI returns an error: "Cutter is not responding to poll size."
  2. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    It could be as simple as using a different cable . . .
    I've had the brand of cable be an issue before - go figure, but worth a try !
  3. Greenthorn
    Greenthorn Member
    147
    It's the same serial cable I've been using. But I will leave that as an option to try. Don't think I have an extra one of them lying around though.
  4. signage
    signage Major Contributor
    9,315
    41
    48
    Oct 5, 2005
    Penn
    Are you running same OS? Check your firewall settings.
  5. Replicator
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Same serial cable, but new/different computer . . . That's when it happened to me !
  6. Greenthorn
    Greenthorn Member
    147
    New computer is running Media Center and will go to Vista soon.
    I will see if I have another serial cable, if not, I'll buy another one and check that.
    Thanks for your help.
  7. imaSIGNr
    imaSIGNr Very Active Member
    2,581
    3
    Have you tried a parallel cable ?
  8. signage
    9,315
    41
    48
    Oct 5, 2005
    Penn
    I think it may have something to do with windows media center!
  9. geedub
    geedub Member
    385
    did your old machine have service pack 2 installed?
  10. Greenthorn
    Greenthorn Member
    147
    Haven't tried the parallel cable - but I don't think polling works using a parallel cable anyway.
    The old (and still) sign computer is using XP SP2.
    I'll have some time this weekend to dig through my useless box of old computer cables and parts to see if I have another serial cable.
    I suppose the worst case scenario is that the old computer could stay and just run production manager, and use the new computer to do all the design work.
