LXI Software question....
Discussion in 'General Software' started by SouthboundDesign, Mar 20, 2005.
  1. SouthboundDesign
    SouthboundDesign New Member
    16
    I just got my Panther 24 in and I am working on a car graphic for a Honda civic.
    My design:
    All the design is done in illustrator. The design is a straight line that breaks apart as it goes back. The design is black and I used a white block shape to (delete) create the spaces as the line breaks apart and the end.
    My issue:
    So as I bring the file into LXI I have the white blocks as shapes and it does not allow me to cut as if the white blocks where just punch outs of the black line.
    My question:
    In LXI how do I punch out/ knock out the white (shpaes) with out having to redo the design as single black shapes?
    I hope someone can understand what I am asking.
    Thanx-
    Anthony "ACE" Cox
    Southbound Mobile Graphics
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    In Flexi you would perform a "Cutout" command. I believe you software is a private label version of Flexi.
    I don't have my Flexi available where I'm at so from memory and based on your description:
    1. Select all the white blocks and compound them (Control + M). Deselect.
    2. Selection order determines what will be cutout, so follow this sequence. If you get the wrong result, Undo (Control + Z) and select again in the opposite order. Select the black shape and then select the white shapes. Execute a Cutout command. If the result is correct and the white blocks do not automatically delete themselves, delete them manually.
  3. SouthboundDesign
    16
    Thanx for your help that was all that I needed. The design came out great. I will post a picture as soon as I install the design.
    Anthony "ACE" Cox
    Baton Rouge, LA
  4. CDC Graphics
    CDC Graphics Member
    83
    LXi question.
    I have VE LXi Master+7.5v5 and I need to weld this image. I go through the steps but it doesn't work. The horse needs to be cut out with the diamonds but it doesn't work when I send it.
    Can anyone help me!!??
    Thanks.
    Answered my own question. It would do a cut out with an outline. Hmm...:help:
