Lxi
Discussion in 'Flexi' started by letsoren, Jan 1, 2007.
  1. letsoren
    letsoren New Member
    19
    LXI. Has anyone heard of or used this program? Thanks
  2. signsource1
    signsource1 Member
    49
    We use it, daily and have since 2001. There are several versions, we uae ours to send code to our smaller plotter. We also use Photoshop, Illustrator, and Inkscape (limited)
    Do you have a question?
  3. Larry G
    Larry G New Member
    10
    LXI is a house brand created for signwarehouse. It is made by the same people who make FLEXI. LXI master plus is the same software as FLEXI PRO.
  4. signage
    signage Major Contributor
    9,497
    71
    48
    Oct 5, 2005
    Penn
    LXI is usually one version behind flexi.
  5. imaSIGNr
    imaSIGNr Very Active Member
    2,581
    3
  6. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    No, the super duper galactic gold master turbo XL premium professional platinum version of LXi is the same as Flexi Expert not Flexi Pro. There is no RIP nor print facility in the top version of LXi.
    Other than that LXi is pretty much bit for bit Flexi with another name.
    The version numbers are the same. I.e. LXi x.y is the same version as Flexi x.y.
  7. Whit
    Whit Member
    295
    Been using it since 2000 when we first puterized !!!
    Had never come in contact with puter or cutting
    software,,, after learning puter,,, LXI was easier
    to pick up on (learning curve) than I'd feared !!!
    We use the LXI Expert here and it does most of
    what we require,,, if not,,, I grab a Brush:Cool 2:
  8. letsoren
    letsoren New Member
    19
    Thanks All!!!!
    Thanks for all the info!
Similar Threads - Lxi
  1. " SQUIRT "
    1
    253
  2. sean franklin
    4
    526
