Why are you running your sublimation print through flexi? Printing and cutting? What are you printing and cutting that's for sublimation?
Do you have/use Illustrator?
To get fullcolor prints on cotton shirts I have to print on sublimation paper; press this on special foil, run this true my Summa via Opos and cut it.
but... I was under the impression that you couldn't sublimate cotton? I just got the GX7000 and am waiting on my inks, so I'm quite interested in this process. Can you elaborate a little?
Sounds like Flexi needs to step up here. Thanks for the info! Because I hate Windows I want to do it on a Mac; which the supplier said it would. But the problem is that I cant get the ICC-profile to get installed in Flexisign.
My workaround is:
-design in Illustrator
-rasterize in Illustrator (because Flexi changes the colors/gradients and so on)
-make contourline in Illustrator
-open in Flexi
-make contourcutline
-save file
-save file to USB stick
-open macbook (because parallel desktop doesn't recognize the dongle on my iMac which has parallel 6 installed)
-open parallel desktop 5 on my macbook
-insert usb stick and dongle
-save file to my documents
-insert printer usb
-print via flexi to ricoh printer
-press the sublipaper on subliflex
-insert vinylcutter USB
-insert sublipaper in vinylcutter
-contourcut via flexi
-f*ck it up with cutting
-and start all over again
understand my frustration? but hey, I can sublimate on cotton!!! woeeeeeehoeeeew!!!
And all this frustration would be gone IF:
flexi would let me install the ICC profiles
so you do the printing and cutting via Illustrator? which plugin do you use and where can I find a tutorial/how to?
I asked around (when not knowing about this forum) and I was told I had to purchase Flexi Print & Cut otherwise I wouldn't be able to print&cut......
I know there is a plug in for Corel for the summa because I have it. I don't remember, but I was fairly certain they had it for Illustrator too.
It's in one of these packages.....
http://www.summausa.com/support/software.php
It's CoCut you're thinking of; they also make their own plug-in, WinPlot, but it only has drivers for their cutters.
Nope, not thinking of CoCut. I have a Summa plug in for Corel, it's got the OPOS icon on it too. Yes, it does take it into winplot. He should be able to do that.
