MacTac metallic enhanced lam?
mudmedia
Has anyone used this laminate on a vehicle wrap? I got a sample today and it looks really nice wish it was a tad more clearer but the metallic flake effect probably has a lot to do with that...Just have questions because looking up specs on it and it says cast laminate but use on flat to slightly curved surfaces? Any input?
4R Graphics
Not sure but most cast lams say slight curves only a few extreme lams say anything else.
Look up the mil thicknes and compare it to the other lams if its the same thickness you should be able to use it like the others if its thicker then it will limit it a little.
If you know what your doing and you install a wrap properlly (not heat and make it fit) but do it the right way you should have no problems on most vehicles.
