Magenta Head on HP 8000
Discussion in 'Hewlett Packard' started by gq_snoops, Sep 3, 2013.
  1. gq_snoops
    gq_snoops New Member
    4
    Sep 1, 2013
    NV
    I'm a newbie to this site, so please bare with me.
    I have a HP 8000 that we've owned for about 4-5 years with almost no issues. We take ridiculous care of our machines.
    We've had this issue for the past 2 weeks. All print heads are firing good except the magenta. It looks like scratch marks are going through when it prints. The nozzle check pattern is perfect with nothing missing. There is no lint or anything on the carriage. I had a tech come out and they recommended that the Capping station be replaced, so he replaced it for us. It ran great or a couple of days and went back to the scratching. Another tech came back out and said that the first tech didn't adjust the capping station correctly so he made the adjustments and it ran great for a couple of days and of course it came back. The tech came back out and could not figure out what was causing this and basically said that I should trade it in for a Seiko Colorpainter W-64s.
    Everything is running great with the exception of this issue. Does anyone have any suggestions?
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    did they change out the dampers as well? could be dampers, any tubing connections (failed o-rings) or perhaps the pump line to waste is clogging
  3. gq_snoops
    4
    Sep 1, 2013
    NV
    Thanks for replying.
    No they did not change out the dampers of rings. They only changed out the capping stations. Should I have the dampers and rings changed for the magenta or all the colors? Is this something that I can do myself or do I need a tech to do this? Where would I order these from? Thanks again.
  4. J Hill Designs
    15,549
    17
    not too familiar with the 8000 so I should let others chime in. on the 9000 they arent too bad to change out.
