I have never personally done this but the only difference between the RJ900C and RJ900X is a firmware change so technically I would assume it's possible. Some Mutoh boards block you from going from one version to a different one but since it's still the RJ900 I would think that would work. If you can't get the parameters off the old board, you just need to start from scratch and do all of the alignments and heat settings again.
