phototec
Has anyone ever replaced the SMT surface mount FUSE for the Roland SP540?
A surface mount fuse is NOT trivial soldering work. Although you can use a regular fine-point soldering iron, it is highly recommended that you use a SMT resoldering station to remove the bad one and a regulated soldering iron to reattach the new fuse. If you have too high of a heat for too long, you may trip the new fuse which means you'll need to get another one.
If you have or not, what are your thoughts, how does the price compare?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370295776873&ssPageName=STRK:MEWAX:IT
