Many errors and the machine MUTOH VJ 1204 does not turn on after 20 minutes
Francine
Hello, can you help me !?
A week ago my Mutoh vj1204 was printing and appeared an error (E016) she got the carriage stopped and not turned off by the button.
I waited 20 minutes and press turn on button, but the same did not turn on. its not normal!
I could connect only after 6 hours, and it printed too little and came another mistake.
A manager has come here, tested the power board and is working.
Is it the motherboard that has a problem and have to change it?
I tried to run it today but did not call.
The errors that have:
E016 TLB / S [03]
E016 Ad err L / I [04]
E016 TLB L / I [02]
e066 CPU error
(I'm using google translator because I speak only Portuguese, then why errors in the writing part, sorry)
Error 16 is a main board CPU error. You can try to take the main board memory out, clean the terminal and reinstall the memory. If that doesn't help, you will need a new main board.
Francine
If the machine "Turn On" I can try to update the firmware of it, can it work?
Unfortunately no. Error 16 means that there is a malfunction in the CPU itself. The CPU is the brains of the printer, so if it fails, it is done for good.
Francine
Good morning people!
We changed the cr motor
Send the mother board for review, has not found defective, an ultrasonic cleaning was made to it.
Today put back, the machine just turn on and gave the error: error 067 and PF encoder.
I hung up and tirn on again, then gave the error: error AddErr-E 016 L / I [04]
They told me that cables can be flats as well.
Is it some other problem that we do not think?
the machine does not turn over after 20 minutes
I do not know what to do, I need some help!
