Material for trade show displays
dhamlett15
I have a customer that has brought me in 3 panels for a trade show display that I need to remake with new graphics.
The material seems to be a pvc or something similar. 23"x48"
Is this a material that I can print on an epson 7600 and if so does anyone have a material that they can recommend?
Also any merchant members that can do these prints please pm me.
BigfishDM
Can you send me a small piece so I can match it up? I have multiple solutions that will work for you but I would like to see what they are expecting.
Slamdunkpro
Intelicoat makes a 12mil aquious polycarbonate that you can reverse print then lay a white vinyl adhesive backer (which they also make) over the back. We used to use this when we had our dye based Epson, I don't think it works with pigmented inks.
We do a ton of TS panels. If all you need is 3 panels that don't require any top/bottom tabs and you don't stock the materials, farm them out.
synergy_jim
You can also print to a material like Lexjet and laminate with a self adhesive polycarbonate lam. There are quite a few companies making varying thicknesses of the polycarb laminate. Kapco is one of them...
