material size
Discussion in 'Mimaki' started by gabagoo, Nov 28, 2007.
  1. gabagoo
    gabagoo Major Contributor
    5,739
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    I was just curious about this issue. When I load my Mimaki with 54" material it will set up and usually the readout will be 52.8". Now if I set my rip to 52.8" and then send a job out with lets say a 1.5" inset, do I really have 51.3" of print area?
  2. ColesCreations
    ColesCreations Member
    415
    1
    What about just printing a stripe on the media and measure what it REALLY does?
    Also, have you measured your 54" media? I am pretty sure our Mimaki shows the width of the Media.
  3. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    The Mimaki only shows the printable area. I can print up to about 53.5" on a 54" roll. You can set the margins to be smaller.
  4. ColesCreations
    415
    1
    Yeah... I was a bit off.
    We have the margins set at -10.
    To be exact, just checked, with 500 mm media (20"), it shows 492 mm, which is 8 mm (5/16") less than the media.
    So- The Mimaki will print 5/16" less than the full width, with margins at -10.
    And, if you want 1 1/2" margins, @-10, then specify 1 11/32" inset, or set the margins @ 1 1/2" and let the printer come up with the answer I guess...
    Back to my initial answer, the easiest way is to print a stripe and check, just to be sure...
    Nice to know...
