max metal to pvc
1leonchen
whats the best way to join max metal to pvc. i want to glue the letters i am doing for a building a little more lift. also the pvc allows me to insert threaded studs.
so i need to join max metal to pvc. max metal is aluminum sheet pvc is just pvc.the sign is a outdoor sign. so i rather not use tapes. must be able to stand hot or cold temps. thanks for the help.
rossmosh
I'd use 3M VHB tape & silicone adhesive. It's a combination that is known to work well and failure rates are very low.
Make sure you get exterior grade PVC.
