Measuring Graphics
Discussion in 'Vehicle Graphics' started by select426, Dec 3, 2010.
  1. select426
    select426 Member
    I was wondering what most people use to line up their graphics on today's vehicles. It seems the lines on the new cars are getting crazier and crazier. When you are doing logos and text what do you guys to to align everything? Do you use the body lines as your reference or do you the ground? We are fairly new in this and are finding with the newer vehicles it is harder and harder to determine to go off your eye/ground or go off the body lines.
    Thanks in advance for any help you guys could give us.
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    body lines then eyeball
  3. jferrell3054
    jferrell3054 New Member
    3
    Anything I can not measure I go eyeball. If it looks good to your eye it should be fine for theirs
  4. natedawg9640
    natedawg9640 Member
    443
    Aug 10, 2009
    Appleton, Wi
    yup. judgment call. you can also lay it out and ask the customer to approve it.
  5. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Bottom of door, body lines, windows, a tic up a tic down by eye sometimes.
    Don't use the ground.
  6. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Bottom of the doors...sometimes just eye. Tape it on and stand back is the best way, even if you have something to measure off of. I HATE when I see van lettering where I know people measure off the top of the van. Vans are smaller at the rear and stuff will go downhill if you measure off the top. Sometimes I even measure from the ground and tape it on and see how that looks.
  7. johnnysigns
    johnnysigns Very Active Member
    1,195
    4
    38
    Nov 3, 2004
    East Coast
    Eyeball and several big steps back. All day. If it doesn't look right and it's "level/measure's out correctly" it still doesn't look right.
  8. cartoad
    cartoad Active Member
    731
    Apr 11, 2006
    Yakima, WA
    We use the line under the windows (or where the windows would be) on vans, usually strait and looks good with the van, if all else eyeball. Always a struggle to find the right line to use.
  9. klemgraphics
    klemgraphics Active Member
    624
    Jan 13, 2008
    Midwest
    +1
  10. Malkin
    Malkin Very Active Member
    2,194
    26
    48
    Feb 11, 2009
    Augusta, ME
    +2 Never go off the roofline on a van...
  11. thesignexpert
    thesignexpert Active Member
    841
    2
    +3 Our rule of thumb for our installers is to "make it look right". This means that it is more important to make sure those graphics look correct on the vehicle rather than trying to later convince a client that it's level. Few things drive me crazier than hearing a guy try to justify a placement by saying they used a level or measured from X,Y or Z... at the end of the day the only thing that matters is that it "looks" right.
    Tim
    "Useful Sign Forms, Marketing Packets and Clipart for the Sign Professional"
    TheSignExpert.com
  12. zapblam
    zapblam Member
    107
    then you get the one guy who wants it LEVEL meaning with a level. Always sign agreement on those debates.
  13. westpointsigns
    westpointsigns Member
    259
    Body lines, door seams, eyeball. I will always take a picture or two and look at it on the camera, as well as walk away from the side I am lining up with the graphic taped in place then come back to it and look at it from a distance if possible.
