Media and laminate question
Discussion in 'Newbie Forum' started by Zack Bunning, Nov 24, 2018.
  1. Zack Bunning
    Zack Bunning New Member
    17
    2
    3
    Sep 9, 2018
    Decatur, IL
    Okay, so now that I have my machine printing good now, I have some newbie questions lol. Is buying rapid air release media worth the extra money if i am going to be laminating it? Also, what media would everyone recommend for doing dirt track racing wraps? Also, a recommendation for laminate film. 80% of my jobs are dirt track racing related. I have always used Oracal products in the past, is that still the best product to use? Thank you guys in advance!
  2. Sindex Printing
    Sindex Printing Member
    157
    39
    28
    Nov 17, 2018
    Sparks
    Check out substance Incorporated. The material one of the best ones for the price.
  3. unclebun
    unclebun Very Active Member
    Air release media is a must if you are going to be doing wraps. It's difficult to get a smooth application even on a flat 4'x8' sign with non-air-release media. And when doing wraps you will need the repositionability of air release wrap media.
    I would say the best material to use is the same thing you would use to wrap any vehicle, a cast wrap vinyl and its matching cast wrap laminate. Whether Avery, Arlon, 3M or Oracal is really up to personal preference. They all will work.
    That said, I have done some modifieds using calendared air release vinyl laminated with a calendared laminate, but we were only doing the flat surfaces on the sides, rear and roof. You'll run into trouble trying to do hood bulges or moulded nose cones with calendared material.
  4. mkmieciak
    mkmieciak Lost Soul
    96
    20
    8
    Aug 14, 2013
    Illinois
    The laminate does not affect the air release. Air release is basically small channels in the adhesive that allows you to push the air out the sides. Air does not "evaporate" from the surface. If I were you I would stick with what you have used and know as far as product. You are probably doing a lot of repairs on the vehicles and different vinyl brands will print differently and your repairs may not match up color wise. If you change product do it in the new season. We use Avery 1105/1360. Not perfect but the most consistent.
    • Agree Agree x 1
    • Informative Informative x 1
