Menuboards
Kwiksigns
wookie
Client wants a 24x24 double sided menu board that hangs from the ceiling and has a half inch border. Making the viewable picture 23x23.
Also wants it to be easy to change out the images but using the same menuboard/frame. Any ideas?
John Butto
Here is my idea, you need to make a 24x24 menu board with a 23x23 viewable area with change out for images and then hang it from the ceiling.
Marlene
build the backing with steel tape applied to it. make the image on 3mm PVC with magnetic tape and just print the image and menu so he can change it out, menu/image al changes at the same time. make as many sets of images/menus as needed. option#2 make tracking so you can slide in image printed on something thin. menu is on clear plexi on stand offs.
by .5" border, do you really mean frame?
