Metallic Decals
ZipSeb
I'm looking to produce sone decals for a client with a metallic finish. I was wondering how people go about producing these WITHOUT a metallic ink printer.
I know Avery has a Clear Sparkle Laminate but I wanted to see what other way people were producing these.
ikarasu
If you have white ink printing on metallic vinyl is a good option, you can put white behind anything you don't want to be metallic and it'll make it opaque. Rtape has a few different metallic option
JSIGN
We find good results printing onto metallic vinyls from GRIFF Company in Lakewood NJ 732-367-2166 with our Roland Eco Sol printer and laminating
MNT_Printhead
Working among the Corporate Lizard People
I recently used some brushed gold Avery SF 100 with my latex to make some fake embossed looking certificate stamps. They turned out well.
bob
Just print whatever you're printing on the lightest metallic silver vinyl available to you. I've used Oracal, 3M, Avery and others. I get the best results with Oracal and 3M since they offer the lightest silver. With Avery I've used whatever they call their relatively coarse silver glitter. Since your white point is now silver you may want to adjust the colors. Silver makes everything a bit darker and yellows tend to be brassy. Just print a Pantone, or whatever you're using, color chart and use that to diddle the colors. I do this all of the time and, since the ink is transparent, it always looks like candy apple paint. The lighter the color the more intense the effect. From light colors to dark their transparency coefficient runs from 100 to 0. The biggest problem I encounter is that my plotter isn't able to read registration marks printed on silver. Your mileage may vary. Nonetheless, I solve this by keeping the registration marks well away from the object to be cut and putting a white vinyl patch on the silver at the location of each mark and then printing. Works for me.
ZipSeb
This worked out great for my job, Thank You Bob
tulsagraphics
Didn't see a mention of your printing method -- but I would just add that not all metallics are good for solvent printing. I've had some metallics do fine, but a handful where the ink basically puddled up. I'm sure the other folks have good recommendations for solvent-receptive films, but I'd want to test it out before committing to a full roll. Some of those films are expensive.
We use our Mimaki CJV series eco-solvent printer to print on metallic vinyl on a semi-regular basis. Orafol 970 silver lake metallic and 3M 2080 gloss white aluminum work very well and produce similar results. We laminate with standard gloss laminate. We also print on Griff metalized polyester films with no problems at all. Griff has a nice variety of metalized films.
