metallic vinyl
Discussion in 'Roland' started by banner, Feb 15, 2011.
  1. banner
    banner Member
    29
    metallic vinyl, how to print the correct temperature xc-540???
  2. zm71
    zm71 Member
    54
    same question, different machine. sp300. anyone? thanks!
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    High temp, the ink does not want to dry. tricky stuff, we print on oracal 851 silver with some luck.
  4. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    My SP-300V prints nicely on oracal 851 metallics or Avery metallic films. I always use the default heat settings 37 / 40
  5. john1
    john1 Guest
    What are you guys doing about laminating though over cut vinyl your printing on?
  6. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    lam first, cut after
    I've printed on clear Orajet, & applied to metallics... looks great!!
  7. toli13
    toli13 Member
    39
    I've done it the same way as iSign. Never had success in printing directly on silver Oracal 751. Will try the 851. Thanks for the hint.
