Methods to mount a full coverage print on a substrate?
Discussion in 'Digital Printing' started by john1, Aug 27, 2010.
  1. john1
    john1 Guest
    Hey, I have not yet mounted a full coverage print onto a substrate, If i had to i have been lucky and could make the print a 1/2" smaller and mount with the BS.
    Any tips guys?
    Have some mags as well as coro to mount soon.
    Thank you!
  2. dweinmann
    dweinmann New Member
    11
    Do you have a laminator? There was a great post (do a search) on how to use a laminator to mount vinyl. You'll save a ton on masking tape!
  3. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    I print with a 1/2" bleed, laminate, trim, line up on board, do a center hinge and lay down one side with the big squeegee, peel up and lay down the other side, trim and usually for kicks seal edges with a Seal-It pen.
  4. AUTO-FX
    AUTO-FX Very Active Member
    2,185
    depends on how big. i center hinge alot just cause it's fast n easy, even though i have a couple laminators and a BS. I will peel back one side and stick a yard stick on the edge - holds it nice and straight while I squeegee across.
  5. Sign_Boy
    Sign_Boy Major Contributor
    6,429
    8
    38
    May 18, 2007
    USA
  6. AUTO-FX
    2,185
    slap it dooowwwnn , baby!
