Mimaki 250 sp, cannot see cartridges black and magenta
boggiom72
I have a 250 SP.
It wasn't working for about two years. The lines were emptied and cleaned out completely.
It's now unable to read the Black and the Magenta chips in my bulk in cartridges.
I changed already the chips with a new one and I also change the receiving sensor without any results.
Any ideas?
Thank you.
Pagan
I have a 250 SP.
when a cartridge set for long time with out moving it ,the two connector
that touch the chips retract and dont make contact with chips
removed cover and try to pull them out a little bt
see if work
boggiom72
I have a 250 SP.
see if work
Do you mean on the printer side?
I did change those connectors entirely and replace them with new ones.
I also placed some spacer to have the chip on the cartridge to push out more so to have a better reach... No luck.
m
Pagan
Next ,check a little switch right under the needle the one that punch
the cartridge . Press and depress couple of time
see if work
good luck
Pagan
Come on , we all here trying to help each other in the most inexpensive way
for solution with our own past troubles and solutions
you change long cable ,slide board and main board if is necessary,
changing parts like many supposedly call "technician" at customers spence
it not what this forum is all about.:thankyou:
boggiom72
see if work
good luck
I'm not sure which needle you are talking about.
You mean on the other side of the cartridge space? Facing the connector that touch the chip?
Thank you.
m
Bulgakov
as Pagan says, it is very possible that the sensor detects that the cartridge will not work.
You can determine which sensor is failing:
Enter in service mode//#test//Sensor test//Sensor test - Ink pad
there you can see if it works.
boggiom72
Thanks!!! Damn i wish I saw this before!
Sorry for my ignorance... How do I enter service mode?
Thx
m
boggiom72
Everythinbg done, still the problem persist...
Next step is a new main board...
I can get one originally on a 160 SP...
How do I switch the setting to a 250 SP? I'm told I can do it changing some parameter in service mode.
m
