Mimaki CG-130FX Annoying USB Problem
spencer2004
Hi.
I have an annoying problem with my CG-130FX when I send cut jobs to it from the computer. The first cut will go fine but if I take it out of REMOTE mode to cut the sheet or something then put it back in to REMOTE it will refuse to cut for some reason. It will receive the data but not perform the cutting job, to get it to cut again I will have to either turn it off and on again or do a DATA CLEAR and remove the USB cable and put it back in again. If I just do a data clear after every cut job it is fine but I would rather not have to do that.
I have the latest driver and the USB cable is not damaged. I am cutting from Windows XP running FlexiSign 8.1.
