Mimaki cg-75 fxwon’t cut the corner
Douglas Hughes
When I do the test square cut it will cut all three corners but it won’t cut the corner where it starts and where it finishes or lettering in the corner.
That's usually going to be a blade offset setting. If you're using the standard blade, the setting should be 0.3.
