I am using the mimaki cutter to cut through convex 12mil material and can't seem to cut through. The blade also slightly scratches?
Anyone know a fix for this problem?
Cheers
Brett
Brett:
Not familiar with the material you are referring to, and your comment "
The blade also slightly scratches"
However, sounds like you need to set the "down force" on the blade so that it applies a little more pressure. That would allow the blade to cut deeper into the material. Go easy as you make a few test cuts till you get the setting correct. Then plot your artwork. If you are cutting 12mm material, I would also suggest you run the plotter a little slower than usual.
One other thing that will make your cut go better. MAKE SURE you have a fresh blade in the plotter.
