Click to Support Signs101 ...
You need to make sure "HLF" is enabled in the settings menu on the plotter. Then use the front foam cutting strip, set the tool from ct1 or whatever to hlf and you're good to go. You can adjust the half cut parameters from the settings menu, spaces of the cut "dashes" etc.
