mimaki cjv 30- 130 firmware version needed
It's going to be hard to find since Mimaki stopped releasing that Firmware a long time ago so the only people who will have it is techs who downloaded it before then. Also, technically, if they work for a dealer, it violates the non-disclosure agreement they sign with Mimaki. If you don't find it, give us a call. We have some solutions that will save you some cash on the head.
kensign
Need a used one just to test the machine. also firmware . .i have problem with tp1-tp8. one tp 3 show 1 one tester. I took it to fix and changed some transistor, c4550 , c1475. Machine start and boot, then error 200 memory board. then a led light came on the mainboard.I connect all cables to sliding board except from sliding board to print head, and a led light on the sliding board. When i shut down and power still led light on sliding board went off slowly , but on the mainboard is still on, as long i have the power connected, panel screen power off normal, mainboard led is always on. I could get my parameters out. Can you suggest. Thanks again
