Active Sign
Sign Guy
Hi all.
I have a Mimaki CJV150-160. Its been an incredible machine for us for the past 4 years. Meticulously maintained, loved, and never ran hard. It worked perfectly until I moved it. I had the machine in a climate controlled room inside my shop in Southern California. I moved the machine as gently as possible inside my cargo van, keeping the temperature above 50º. Once at its new home about 900 miles north I put it in a climate controlled room in my cold garage. I fired it up and ran a test print. The test print is now missing the entire magenta channel on the right side, not even one nozzle. All other channels (including magenta on left side) print perfectly, not a single missing nozzle. I am trying to identify the problem.
So far I have done overnight head soaks, cleanings, Ink fills, swapped the dampers on either side; they print no problem, moved and reconnected the ribbon wires, Ran a small print job. Still no magenta in the test print on the right side.
Does anyone here have any suggestions or techniques that I might be missing? I am trying to avoid the print head replacement. Those things are crazy expensive for this machine.
Thanks in advance.
btw, there are no Mimaki techs in my area. I am on my own here.
Thanks in advance.
