probull
Hi group.
for one customer, the computer connected to the Mimaki CJV150 burned down, the computer was repaired, but the printer stopped communicating.
The USB port not comunicate on another computer either. The dealer diagnosed the EPL3 board as defective and needed to be replaced. The old board looks fine, all the diodes are lit, the transistors are not damaged.
My question... can be the boards just swapped or do you also need to transfer some setup from the firmware?
Ps: Old board try comunicate on my pc only with file setup, usb is not show.
Thank you.
Thank you.
