I've been having an off and on issue with the contour cutting vinyl on our Mimaki cutter. I would send artwork through and release the job to be cut. The machine will feed the correct amount of material and then start cutting horizontal lines in a condensed area and sometimes overlapping the lines and cutting through the wax paper. This doesn't happen all the time, but enough to make me sweat...
Sometimes all I have to do to get it to cut properly is reload the vinyl into the machine and re-release the job. The worst part is the wasted material, because it will start cutting at the end of the artwork after feeding all the paper. When that doesn't work, I'll print registration marks and contour cut using those marks. I'm just getting worried now because i'm going to be getting material where I wont be able to print registration marks, and I wont be able to waste much material since the artwork are going to be approximately 100"+ in length.
I'll check to see if the correct width of the vinyl roll has been recognized, and yes, the machine did scan the correct width of the roll, and the preview looks correct as well. Has anyone seen this issue or know how to correct it?
Software used
Rasterlink Pro 5
Finecut 8.7.4
Illustrator CC
Software used
Rasterlink Pro 5
Finecut 8.7.4
Illustrator CC
