KenMan
Hi,
After cleaning and flushing the print head with Mimaki cleaning fluid and a syringe, the CJV30 won't print at all.
So before I order a new print head, I just wanna be sure that the print head is the problem, and that its not a initial set up problem after removal or some connection issues. The reason of my doubts its that all nozzles are "gone". If they been damaged by the flushing (seals?) I assume that some of them still would work...?
There is no error messages and the printer starts up and act normal, except for that the printer head don't drop out any ink at all on test prints...
When I installed the print head, one of the FFC (flat cables) was not inserted correctly, and a few contacts on the cable was slightly bent with a few scratches. I switched power on before I noticed this. Not sure if that had any impact on the print head. I installed new cables to the print head but still the same result.
I have done" INK FILL UP" and run several test prints - still no ink coming out...
I have checked the contact plate between the print head and head mount plate.
I have also measured the COM line between the print head and the Ink Slider PCB according to Maintenance Manual 5.2.2 Checking Damage of the Print Head (picture). It should be above 10M resistance, and I´ve got from 17M to 0L on TP6-TP13...I assume thats ok and no shortage...?
There is a red LED lightning on the Ink Slider PCB that I could not find out what it means (picture). Is it normal with this LED on or does anyone know was it mean? Could not find anything in the Maintenance Manual.
Does anyone know if there is some more tests or settings that could be done to verify that the print head is "fried" or damaged or how to test if its ok?
Do I need to "set up" the print head some way in the system menus when it has been removed...?
I would really appreciate som help and maybe someone could bring up some ideas or suggestions...Thanks...
Rgds
/Kent
Rgds
/Kent
