Question Mimaki CVJ30-130 INK Cartridge
Joanne Kline
I have 8 Mimaki SS21 ink cartridges in my CJV30-130 printer right now. 4 are full & 4 are just about empty. Will I be able to replace the 4 empty cartridges with CAL-ECOCART-MIMAKAI440-A. Will this work with 4 original Mimaki SS21 cartridges & 4 CAL-ECOCART cartridges or do I need to have all 8 of MIMAKI or all 8 CAL-ECOCART? I'm trying to find best price & quality for SS21 ink cartridges in Canada - any help is appreciated!
Call the manufacturer of the ink and ask if there is a conversion procedure. Most, but not all, 3rd party inks are plug and print these days. Also, check out Bordeaux. I know for sure they work great in that machine.
Joanne Kline
Joanne Kline
Thank you VanderJ! I haven't received reply from manufacturer yet but will check into Bordeaux.
I want to do an ink fill
I have
4 full cartridges, CMYK
3 cartridges nearly empty MYK
1 cartridge empty. C
Will my ink fill work with one empty cartridge?
I have
If it is the initial ink fill to fill an empty machine, you need all 8 carts to be able to do it. If you run out half way through it will fail. To run the machine you only need 4 carts but the fill up requires 8.
JasonMeisnerSTS
Joanne,
I would love the chance to supply you with our inks. I represent STS Inks and we manufacture our inks here in the States. I can explain to you how it works mixing OEM and our inks and how we can support you directly. Being the end user, it is very important you connect with the right manufacturer or supplier and our inks are plug and play with OEM Mimaki inks. I hope to hear from you soon, my direct info is listed below.
