Hello all. First let me say that I am not only new to the forum but to the process of Print/Cut Vinyl.
We are running a Mimaki CJV 150-75 along with Rasterlink 6 V5.15 and Finecut 8. I have had no proper training on this machine and have been figuring it out as I go. I have managed to set up a print/cut job and align the two steps (pretty proud of that one). The issue is now with Print/Cut heat transfers. On smaller prints, 4" x 4" or so, there is no problem. But on larger jobs, 12" x 9", I am having difficulty with the vinyl. Weeding is going fine. But after applying the carrier film over the vinyl I cannot remove the film from the back. it pulls at the vinyl and stretches it or pulls it from the adhesive sheet.
We are using Briteline G-Flex Supersoft 233 with the recommended HTV 854 Transfer tape.
My thoughts are that the dryers on the printer are heating the vinyl too much and causing it to bond with its carrier sheet. On smaller jobs it hasn't been a problem. Has anybody had this problem or some suggestions on what the problem might be?
