Mimaki jv3 250sp new problems
Pagan
NEW PROBLEM ARRIVE . AFTER I INSTALLED CSV FILE. I TRY TO GET TO #ADJUST OR TRY TO INSTALLED NEW FIRMWARE
PRESSING FUNCION+ REMOTE OR < >, NOTHING COMES UP , NO BEEPS .I CHANGE KEY BOARD, NOTHING HAPPEN. HELP:banghead:
Pagan
Problem solve
problem solve , Bought a new main board $1800.00 later ,bingo printing again:rock-n-roll:
Pagan
New for me
ACTUALLY,I BOUGHT A USED MIMAKI JV3 SP FOR 1800.00 , WITH 3 NEW PRINT HEAD ONE OLD HEAD BUT IN GREAT PRINTING CONDITION
PLUS I GET THE SLIDE BOARD,IO BOARD, IO2 BOARD, POWER SUPPLY ,IF BOARD , MAIN BOARD AND ALOT OTHER PARTS.
CHANGE PARAMETER FROM 160SP TO 250SP AND PRINTING AGAIN. I THINK I MAKE A GREAT BUY.:toasting:
Pagan
Changing parameter
How did you change the parameter? i need help please... thanks
Do this: when the printer boot and show the firmware version press REMOTE + FUNCION at the same time, you going to hear a beep , after that go to FUNCION
And go down pressing the v key into you find parameter, some parameter you can't change they are secret
number mimaki never release . Here is the list
5-5. #PARAMATER items
5-5-1. SYSTEM PARAMETER[Function]
System parameter values are changed.
[System parameters list]
page153image2520
No.
Indication
Set value
Description
Remarks
COMP.X
Mechanical correction X
(in increments of 0.1 mm 500 mm – actual measured value)
Adjustment of rangeaccuracy
If the system parametervalue is incrased:
Length of a patternplotted will be increased.
1
COMP.Y
44
Mechanical correction Y
2
R GRIP
Adjustment of dead space on the right-hand side of the paper(in increments of 0.1 mm 25 mm - actual measured value)
Adjustment value foredge adjustment
If the system parametervalue is increased:Dead space will bereduced.
3
L GRIP
Adjustment of dead space on the left-hand side of the paper(in increments of 0.1 mm 5 mm - actual measured value)
4
CAPpodY
20
Adjustment of capping Y position (in increments of 0.1 mm)
5
PULLpos
25
Idle suction position (in increments of 0.1 mm)
6
FLSposY
Adjustment of flashing Y position (in increments of 0.1 mm)
7
WIPposY
35
Adjustment of wiping Y position (in increments of 0.1 mm)
8
RESERVE
RESERVE
9
CUTposi
Adjustment X of the medium cutting position(in increments of 0.1 mm)
Adjustment value in theX-direction when cuttingIf the system parametervalue is increased:Remaining portion of thepaper after cutting willbecome larger.
10
EDGE LV
50
Medium edge detection level (Unit: %)
Edge detection levelwhen the medium widthis detected
11
H12dist
252
Distance between head 1/nozzle row A and head 2/nozzle row A
12
H13dist
640
13
H14dist
792
Distance between head 1/nozzle row A and head 4/nozzle row A
14
RESERVE
RESERVE
19
RESERVE
RESERVE
20
FEEDadj
25
X feed pulse correction (in increments of 1 dot)
21
V1BiADJ
Correction base value for V1 waveform Y direction shuttle movement(in increments of 1 dot)
22
V2BiADJ
Correction base value for V2 waveform Y direction shuttle movement(in increments of 1 dot)
No.
Indication
Set value
Description
Remarks
23
N1BiADJ
Correction base value for N1 waveform Y direction shuttle movement(in increments of 1 dot)
24
N2BiADJ
Correction base value for N2 waveform Y direction shuttle movement(in increments of 1 dot)
25
V1HBiAJ
6
Correction value for V1 waveform doubled shuttle movement(in increments of 1 dot)
26
V2HBiAJ
4
Correction base value for V2 waveform doubled shuttle movement(in increments of 1 dot)
27
RESERVE
RESERVE
28
RESERVE
RESERVE
29
RESERVE
RESERVE
30
WormORG
Worm origin
0: normal (cm/s)
31
RESERVE
RESERVE
41
RESERVE
RESERVE
42
CUT.OVL
Medium cut over run (Left)
43
CUT.OVR
Medium cut over run (Right)
44
CUT.spd
Cutting speed
45
RESERVE
RESERVE
46
QC3636
41
Print Quality 360 x 360
47
QC3654
41
Print Quality 360 x 540
48
QC3672
41
Print Quality 360 x 720
49
QC7272
41
Print Quality 720 x 720
50
QC1472
41
Print Quality 720 x 1440
51
QC1414
298
Print Quality 14400 x 1440
52
FlashSW
1
Periodical Flashing Switch
0: Disabled / 1: Enabled
53
PMPsign
RESERVE
RESERVE
55
Ext.CND
Command extension
56
FEEDlow
30
Long direction feed rate (1mm/s)
Medium feed speed whentotal feed is 9mm or more
57
PAGE
Page length clip
0: The page length command is activated,and clipping is done
on the page.
n: The page length command is inactivated, the plot is plotted and
a margin is added at the rear end.
Indicates the action whenthe plot length exceedsthe page length.
58
OEM
For OEM
0: JV3 / 1 : SPZ
59
USE INK
INK type
60
MECAsiz
Mechanical size
0: 54 inch1: 63 inch2: 100 inch
61
HASH
Hash check pass
0: check pass(forced startup)
1: check pass & survomotor OFF
62
SUPPORT
Adjusting function extension
2: Released
3: Released + English
63
INITIAL
Initialization
  1. 1: All parameters areinitialized.
  2. 2: Only system parameter
  3. 3: All parameters are
    secret.
