Mimaki Jv3 Pleas Help
nardi
MIMAKI JV3 HAS BEEN IN A GOOD WORKING CONDITION , DURING THE PRINT THE PAPER WAS BLOCKED OUT AND AFTER THAN IT STOPPED AND IT DOESNT SHOW TEST AND ERROR NEITHER !!! PLEASE HELP IF SOMEONE KNOWS HOW TO FIX IT ???? THANK YOU
nardi
The Encoder is activated and it shows the light ON , it doesn't give any error on the display , The printer measures the paper well, and when i want to do a TEST it doesn't show anything "exactly" it doesn't print anything!!! There is enough ink on the dumpers and the Head works well, it only doesn't print !!!
Can anybody know if there is an optional solution how to fix this ??? Thank you for helping .
OmegaAdv
Im not a tech but after me exactly tech tell you that is the right symptoms for problem in encoder sensor, try other sensor.
