mimaki jv300-160
abdullaha
abduallh
I own machine
mimaki jv300-160
I have a problem as in the picture
What is the solution
abdullaha
abduallh
Looks like a bad ribbon cable or slider board to me.
Thank you my friend for your response
Can you provide us with images of the pieces proposed by the
The only piece of information changed the cap station and did not notice one utility
jfiscus
Rap Master
Power off the machine. Take the cover off the dampers/heads. carefully remove one cable and write how it was connected onto it.
Remove another cable and do the same thing. Swap the cables locations. Power back on the machine and see if the problem moved with the cable. If so - bad cable, if not - probably bad board (that the cables go into).
