Mimaki JV33 Error 207 *UNDERFLOW*
Cmind335
:banghead:So I'm printing like any regular day, the machine finishes the print and all of the sudden a steady BEEP goes off. No messages or nothing. The control panel is frozen so I turn the machine off, waited and turned it back on and everything was fine. Later on went to do a cleaning and in the middle of it, boom!, the same thing again only this time the display read: ERROR 207 *UNDERFLOW*. Turned it off and on and back to normal. So does anybody have an idea of what this UNDERFLOW error is?
Thanks in advance for your help!
Carlos
GFXsol
Vinylman
It has to due with the micro voltage being out of tolerance with factory settings.
From what I can gather from the service manuals you MAY be facing the possibility of replacing the main pcb board. Usually a trained service rep will be needed.
