Missing contour cut lines when using Cloud
IsItFasst
Started using the latest version of Flexi this week and I noticed on a few files when I add a cut line it doesn't actually add it. You can't see it on the file and it doesn't cut but it DOES show up in design central as having one. This is a simple cut around a contour shaped outline. Even if I separate the contour from the detailed design and go to a cut line it doesn't show up unless I check the "with holes" box even though there are no holes in the shape. Very odd behavior.
