Mix coolant
Border Press
Hi I have an Arizona 318 GL Flatbed. I just received a new bottle of coolant but it looks different from the previous bottle we used to use. Canon said this is the bottle they sell now instead. It's a clear liquid and the previous one was green. Is it okay to mix it with the coolant it already in the machine or do I need to flush it all out or something?
Cory Marcin
We run an EFI H1625 Flatbed. Our coolant went from clear to blue. I asked EFI the same question and they said it was fine to mix the two coolants. I know this isn't the same printer, but I thought I would offer my experience with the subject.
Good luck!
Andy D
I have run about 10 different types of printers, including a couple of UV flatbeds & have never heard of "coolant" WTF is it used for?
  • Agree
Reactions: 1 user
AlsEU
To cool the lamps. Even LED UV requires coolant.
It's clear that you have no idea about the Arizona flatbeds. These machines use so-called 'coolant' to heat up the heads and keep them in proper temperature. UV lamps are cooled with the fans.
