Mixing Vinyl brands on t-shirts
Discussion in 'Printwear' started by Clear Choice, May 28, 2011.
  1. Clear Choice
    Clear Choice Member
    182
    Can I put different vinyl brands on the same t-shirt
    even though the times and temperatures are
    different?
    For instance: I have Fibron Black that takes 345 F
    and 20 sec. But the Siser Easy Weed green is 300
    for 15 sec.
    Will the extra heat and time cause problems with
    the Siser?
    TIA
    Sue2
  2. WildWestDesigns
    WildWestDesigns Major Contributor
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    That just adds different variables to the mix. Now if you are putting down the black first and than the green (which has the lower temp) than that might not be an issue. However, you still have to worry about how well it will adhere to the other brand.
    I haven't really tried this with vinyl on shirts as I tend to use one brand anyway, once I find what I like, but for other products I do notice that while there might be some quality difference between two products from the same brand. There is a big difference between the same product between two different brands and parts don't translate all that well to the other.
  3. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
    Why do you try it on a practice shirt and see.......????
  4. WildWestDesigns
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    Doesn't really need to do it on a whole shirt. Just some leftover scraps that match the material would work. Just so long as they could simulate the process.
  5. Pro Image
    4,550
    Nov 28, 2005
    Thats what I meant............:thumb:
  6. WildWestDesigns
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    I gotcha:thumb:
  7. Clear Choice
    Clear Choice Member
    182
    Actually, I was trying to think ahead.
    I've only purchased Thermoflex and Fibron (re-branded Thermoflex).
    BUT, occasionally I see some good deals on the Siser EW and
    I wondered if there would be problems using two vinlys on the
    same shirt that have such different heat settings.
    Maybe someone here has already tried it and could let us know
    how it worked.
  8. WildWestDesigns
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    Sometimes you have to experiment on things yourself. Even if someone else has done it, they might have had to do other things that take practice to get the hang of.
    Not trying to be a smartass here, but there are some things that do have to be done on your own.
    Oddly enough, trying to think ahead has gotten me into trouble a time or two, not often, but it has.
  9. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    The times and temperatures give for various thermal material are ball park minimums. You can crank it up a bit for most any media with no ill effect.
    But if you're really worried about it, do the high time and temperature media first then do the lower time/temperature media. That way you're not exposing the lower rated media to the higher rated environment.
  10. Fivestar
    Fivestar Member
    29
    You can mix and match those brands together with no problems. Set your temp at 325 and press.
  11. binki
    binki Premium Subscriber
    1,542
    40
    48
    Jul 23, 2007
    The PRC
    if you can put the one that has a higher temp on first. if not then that is ok, the temp will not affect the vinyl already on the shirt once it cools down.
    just dont fold it until it is cold.
  12. Mike_Koval
    Mike_Koval Active Member
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    Mixing and matching vinyl is fine. I recommend pressing the higher temp first then the lower temp.
    I would also recommend performing a test if possible as well. While most heat applied materials will work with the next brand, there is still a chance that it will not. Also be sure that when doing multi colors, be sure that the base layer is not a PVC based vinyl. PVC is is good for one color only.
