natedawg9640
Hi Guys. Unsure where this belong actually but I have a customer who is looking for a custom graphics solution on polypropylene items such as coolers. Also, the areas to be decorated may be textured.  AND to top it all off, it needs to be low run, like... one-off custom each time.
I have seen something called mold-on imaging where it appears that a design is screened onto a tranfer film, then placed and hand burnished to the item and post heated to a cure temp to fix the graphic permanently. However, if it's screen based, that doesn't work with the one-off needs in an economical fashion.
My other thought was di-sublimation but with the items being bulky and awkwardly shaped, they wouldnt be able to fit in a press or anything of that nature.
Additional thought is just a vinyl with a high bond adhesive and a hardy over laminate... but the wear and tear that the item sees might be quite excessive and the customer is hoping for something more permanent and aesthetically pleasing. Not to mention that adhesion to that plastic is difficult even on glossy surfaces.
Does anyone have any input or experience with this?
Any advise is greatly appreciated.
Nate
Nate
