Hi Everyone,
I've just started in the sign industry and have done my first mistake laminating a Monomeric Laminate onto Polymeric Vinyl.
I have learnt from Google that monomeric and polymeric behave different hence not to mix the two.
However given I have already done it, and the sign is quite large at 2400mm x 1200mm, I am writing to see if anyone has seen a job with this combination and if so, what will happen and are the effects immediate?
i.e. Will it be good enough to last a few years as it is, or should I throw it out and re-do the job.
The sign is outside in full sun for a few hours each day.
Thank you.
Thank you.
